Sets the value for Address Resolution Protocol (ARP) reachable time
reachable-time | Specifies setting the ARP reachable time. |
reachable_time | Sets the value for the ARP reachable time (range is 1–1,474,515,000 milliseconds or 1–1,474,515 seconds). |
auto | Specifies having the ARP reachable time set automatically to 3/4 of the configured ARP timeout (default). |
milliseconds | When setting the reachable time value, specifies milliseconds as the time unit (range is 1–1,474,515,000). |
seconds | When setting the reachable time value, specifies seconds (range is 1–1,474,515) as the time unit (default). |
The default setting is for the reachable time to be set automatically to 3/4 of the configured ARP timeout. If you set the time manually, the default unit of measure for the value is seconds.
configure iparp reachable-time 500000 seconds
This command was first available in ExtremeXOS 11.1.
